[Gdal-dev] OSR tests fail on Mac OS
William Kyngesburye woklist at kyngchaos.com
Thu Oct 25 17:17:35 EDT 2007
How are you linking PROJ?  I've found that the --with-proj-static
works best on OSX, so that it works just like any other dynamic library.
On Oct 25, 2007, at 3:09 PM, Mateusz Loskot wrote:
> Hi,
> I just tested complete rebuild of GDAL SVN trunk
> and tried to run autotest on Mac OS.
> Two tests osr_ct.py and osr_ct_proj.py fail and here is the output:
> http://mateusz.loskot.net/tmp/gdal-autotest-osr-failure.html
> I have GDAL_DATA set correctly, pointing to trunk/gdal/data location.
> Any idea?
> Cheers
> Mateusz Loskot
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
