[Gdal-dev] svn build error
Joaquim Luis jluis at ualg.pt
Sat Oct 27 23:36:01 EDT 2007
Lucena, Ivan wrote:
> Joaquim,
> The name of that library HD421md.lib could be related to HDF4.
> But HDF4 flags are commented on make.opt:
> http://trac.osgeo.org/gdal/browser/trunk/gdal/nmake.opt#L185
> Is it possible that your make.opt has HDF4 flags uncommented by mistake?
No, it's not by mistake. I normally build GDAL with hdf4 support but
apparently the current (tonight's) nmake is trying to link
against the HDF4 debug version. Hence the 'd' in "HD421md.lib"
> Saudações,
> Ivan
e + Cumprimentos daqui
Joaquim
