[Gdal-dev] svn build error
Lucena, Ivan ivan.lucena at pmldnet.com
Sun Oct 28 00:14:34 EDT 2007
Joaquim,
> No, it's not by mistake. I normally build GDAL with hdf4 support but
> apparently the current (tonight's) nmake is trying to link
> against the HDF4 debug version. Hence the 'd' in "HD421md.lib"
You are right. I usually compile GDAL with HDF41r5s and I just update
the whole GDAL tree from SVN and got the same error but with
"HDF415md.lib".
Ivan
