[Gdal-dev] svn build error
Lucena, Ivan ivan.lucena at pmldnet.com
Sun Oct 28 17:29:50 EDT 2007
Mateusz,
> - For end-user purposes, GDAL should be compiled using non-debug
> optimized configuration and link against non-debug version of HDF.
OK. That is very simple to do and they can get the binaries from:
ftp://ftp.hdfgroup.org/HDF/HDF_Current/bin/windows
> - For development purposes, debug builds are required, and in that case
> it's reasonable to build debug version of HDF from sources,
> because as I understand, there is no HDF SDK in binary form available.
There *is* binary a distribution available at:
ftp://ftp.hdfgroup.org/HDF/HDF_Current/bin/windows/README:
This directory contains the HDF 4.2r2 binary distributions (HDF
libraries, include files, utilities, man pages, release notes)
for Windows:
    42r2-win-cygwin.zip
    42r2-win-vnet.zip
    42r2-win-vs2005.zip
    42r2-win-vs6.zip
But like I said before, this distributions doesn't carry debugging
library.  So, like you said, in this case we need to download the source
ftp://ftp.hdfgroup.org/HDF/HDF_Current/src/  [+ Zlib, Jpeg, Szip ]
Change the compiler setting to generate debug libraries and build the
whole thing again.
I needed to do that anyway to update my old 415r2 version. :)
Thank you very much.
Best regards,
Ivan
