[Gdal-dev] Re: Motion: Release 1.4.3RC2 as 1.4.3
Mateusz Loskot mateusz at loskot.net
Mon Oct 29 04:47:23 EDT 2007
>> Motion: To release 1.4.3RC2 as 1.4.3
>> Once again, starting the timer for a release on Tuesday evening if
>> no serious problems are found.
>> Best regards,
> Folks,
> Garr.  Ok, I'm -1 on RC2.  The pymod/gdal_wrap.c has an older timestamp
> than pymod/gdal.i because of the vagarities of how svn checkout works, and
> this results in builds of the old python bindings running the (likely)
> wrong
> version of swig, and gdal_wrap.c being screwed up.
>   http://trac.osgeo.org/gdal/ticket/1954
> I've fixed (worked around) one aspect of this and I'm asking Mateusz to
> modify mkgdaldist.sh (used to prepare release and nightly snapshots) to
> use svn export instead of svn checkout.  Apparently svn export uses file
> dates of last commit instead of the date at checkout.
Frank,
I applied requested fixes and closed the ticket as fixed.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
