[Gdal-dev] 1.4.3 build and NG bindings
Brian Hamlin maplabs at light42.com
Mon Oct 29 15:42:57 EDT 2007
(I've been talking to William K. off-list) The short Macintosh-specific
answer seems to be:
If you have /usr/local/bin _before_ /usr/bin in your path, the python
install should work without help
    the pymoddir path I suggested is correct, but should only be needed
if there are problems
   -Brian
On Oct 29, 2007, at 8:49 AM, Brian Hamlin wrote:
> Hi All-
>   I am still getting used to the details of GDAL/OGR. I found the
> output of the configure script to be a little confusing regarding NG,
> or Next Gen bindings and building. Howard Butler clarified it pretty
> well, so I am repeating that here. I hope this helps others with this
> build.
>   NG Bindings, or Next Gen, means SWIG. So if you are using a SWIG
> binding in any language, that is NG.   -  Originally there was python
> only, in a directory called pymod, and that alone is not NG. With
> 1.4.3 you can still specifiy the pymod python interface.
>   --with-python  => pymod interfaces
>   --without-python  --with-ngpython  =>  SWIG python, these are the
> preferred interfaces in the future
>   On the Macintosh, I have a new Framework python installed, version
> 2.5.x. Configure will not find that. You can tell configure to put
> your python support files in the framework python on the Mac. It seems
> to be this
> --with-pymoddir=/Library/Frameworks/Python.framework/Versions/Current/
>  hth
>   -Brian
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
