[Gdal-dev] 1.4.3 build and NG bindings
Christopher Barker Chris.Barker at noaa.gov
Mon Oct 29 17:32:15 EDT 2007
Brian Hamlin wrote:
> I used the Mac specific installer for python 2.5.1, and I didn't get
> anything like that
oh well.
> I thought that my post would be simple enough to be helpful to the
> casual user, as I aspired to be
I think the key is this:
>> what you get when you type "python" on the command line
>> should be what the GDAL build system finds.
If that's not the case, then we need to fix the GDAL build system.
If a user doesn't get the python they want when they type "python", then
it is a python install issue, and help can be found on the python-mac
mailing list.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
