[Gdal-dev] Universal GDAL build on OS-X ??
William Kyngesburye woklist at kyngchaos.com
Mon Oct 29 20:36:44 EDT 2007
On Oct 29, 2007, at 6:41 PM, Christopher Barker wrote:
> William et al,
> NOTE: This is all SVN trunk, on OS-X 10.4.10
> I've got close!
> It looks like I have GDAL building Universally, and the python
> bindings building, but something went wrong in the install stage. It
> looks like I've got the Framework mostly OK, but when I try to
> import geos.gdal, I get:
> ImportError: dlopen(/Users/cbarker/.python-eggs/GDAL_OGR-1.5.0-py2.5-
> macosx-10.3-fat.egg-tmp/osgeo/_gdal.so, 2): Library not loaded: /
> Library/Frameworks/GDAL.framework/Versions/1.5/libgdal.1.dylib
> Referenced from: /Users/cbarker/.python-eggs/GDAL_OGR-1.5.0-py2.5-
> Reason: image not found
> indeed, there is no:
> /Library/Frameworks/GDAL.framework/Versions/1.5/libgdal.1.dylib
> but there is a:
> /Library/Frameworks/GDAL.framework/Versions/1.5/GDAL
> and a:
> /Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/libgdal.dylib
> which is a link to the "GDAL" file above.
> I made another link to it:
> $ ln -s GDAL libgdal.1.dylib
> and now osgeo.gdal imports OK -- I've yet to test.
Right.  Known problem.  I mentioned it to Frank, but didn't do a bug
report yet.  The problem is that the framework build does its stuff
during install because currently libtool can directly make "GDAL" as
the libname but must create "libgdal.dylib".  So install_name_tool is
used during install.
But, the path to the ng python install is not known to the GDAL
makefiles, that is handled by distutils/setuptools, so it can't run
install_name_tool on it.
I can hack libtool to do it right, but I don't know if it's possible
to configure libtool to do it right.
The other possibility is some other option to distutils/setuptools to
completely override the python install path, then install_name_tool
could be used.
I'm waiting on some decision about where to install the python
extensions - the system path (the problem would remain), or alongside
GDAL (can use install_name_tool).
Or maybe there is something that can be done in the makefile to
determine the python install path?
> A few other questions:
> The utilities are getting put in:
> /Library/Frameworks/GDAL.framework/Versions/1.5/Programs
> Is that the Apple standard? Should/could there be symlinks in /usr/
> local/bin also? I hate adding all that stuff to my $PATH.
It's really my standard, to keep the whole package selfcontained.
With my binary release I do include a script to create symlinks in /
usr/local/bin.  But I'm not a unix stickler like some, so I don't mind
having a long PATH.
The unix symlinks are also my stuff - I call it the "unix
compatibility" part.  So the frameworks can easily be used in packages
that don't know about frameworks.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
robot?
answer...
