[Gdal-dev] Backporting a change from 1.5 to the 1.4 branch?
Robert Banfield rbanfield at weogeo.com
Fri Sep 7 14:06:44 EDT 2007
Thank you for the quick reply,
Yes, "branches/1.4/gdal/frmts/raw/envidataset.cpp" does not output
correct header files whereas the version at
"trunk/gdal/frmts/raw/envidataset.cpp" does.
Thanks again,
Robert
Mateusz Loskot wrote:
> Robert Banfield wrote:
>> Is it possible to backport frmts/raw/envidataset.cpp in 1.5 to 1.4?  The
>> fixes in there would help us out tremendously.
> Technically, yes it is possible.
> Do you mean 1.4 as branches/1.4 [1] where we will release 1.4.3 version
> from?
> Frank, is it safe to port these changes?
> [1] http://svn.osgeo.org/gdal/branches/1.4/
> Cheers
