[Gdal-dev] Re: [GDAL] #913: NITF driver fails for some CADRG tiles
Sophia Parafina sophia.parafina at ionicenterprise.com
Mon Sep 10 15:23:37 EDT 2007
Even,
Thanks for the patch, but unfortunately it does not solve the problem
with incorrect coordinates.  I see in the patch that gdal looks at the
IGEOLO data to get the corner coordinates.  I looked at the file in a
NITF validator tool called CIVA
(http://www.gwg.nga.mil/ntb/baseline/software/jitctest.html) to check
the value of the IGEOLO fields.
Here's what CIVA returns:
ISH [1] ->*ULIGEOLO*
15 bytes @0x353 bytes
*Contents *
"741119N1613354W"
*Pass *
*Status *
*Message *
Character Set
OK
"The field is compliant with the specification for Basic Character
Set-Alphanumeric."
1
OK
"This field did match one of the format specifications."
2
OK
"There were no values or ranges to check."
ISH [1] ->*URIGEOLO*
15 bytes @0x362 bytes
*Contents *
"741119N1613354E"
*Pass *
*Status *
*Message *
Character Set
OK
Set-Alphanumeric."
1
OK
2
OK
ISH [1] ->*LRIGEOLO*
15 bytes @0x371 bytes
*Contents *
"825544N1350000E"
*Pass *
*Status *
*Message *
Character Set
OK
Set-Alphanumeric."
1
OK
2
OK
ISH [1] ->*LLIGEOLO*
15 bytes @0x380 bytes
*Contents *
"825544N1350000W"
*Pass *
*Status *
*Message *
Character Set
OK
Set-Alphanumeric."
1
OK
2
OK
 Here's what gdal returns:
Corner Coordinates:
Upper Left  (-148.2825256,  74.1886117)
Lower Left  (-148.2825256,  82.9289322)
Upper Right ( 148.2825256,  74.1886117)
Lower Right ( 148.2825256,  82.9289322)
Center      (   0.0000000,  78.5587719)
The bounding box from the IGEOLO are not square, also the longitude is
reported by gdal is the average of the longitudes in the IGEOLO fields.
Is a non-square BBOX a problem for gdal?
Regards,
sophia
Even Rouault wrote:
> Sophia,
> thanks for testing the fix for bug #913.
> What's annoying is that I've just tested your file and it works fine with the
> svn version of GDAL trunk (as well as a version of GDAL 1.4.2 that I've
> patched). Just out of curiosity, I've removed the fix for bug #913 and
> another CADRG bug I've fixed, and your file is still working fine...
> Even more, it is still working fine with the official GDAL 1.4.2 release. Are
> you really sure you're linking with the good GDAL library ?
> I can't see other explanations for the moment.
> Your first message said that the bbox displayed was not correct. I get the
> following results with GDAL svn trunk :
> Corner Coordinates:
> Upper Left  ( 160.3951807,  59.5397891) (160d23'42.65"E, 59d32'23.24"N)
> Lower Left  ( 160.3951807,  59.0220518) (160d23'42.65"E, 59d 1'19.39"N)
> Upper Right ( 161.4361446,  59.5397891) (161d26'10.12"E, 59d32'23.24"N)
> Lower Right ( 161.4361446,  59.0220518) (161d26'10.12"E, 59d 1'19.39"N)
> Center      ( 160.9156627,  59.2809204) (160d54'56.39"E, 59d16'51.31"N)
> Best regards
> On Monday 27 August 2007 19:52:21 you wrote:
>> Even,
>> I rebuilt gdal with the patch but I get an error with the attached
>> file.  Here is the error I get:
>> ERROR 3: Unable to read 6144 byte block from -16705196.
>> ERROR 1: IReadBlock failed at X offset 1, Y offset 3
>> I've attached the file, it is a tile from a CADRG cd.
>> Thanks,
>> sophia
>> Even Rouault wrote:
>>> Sophia,
>>> I don't know what your exact problem was, but bug #913 has just been
>>> fixed in GDAL trunk subversion repository and will be available in GDAL
>>> 1.5.
>>> See http://trac.osgeo.org/gdal/ticket/913.
>>> Could you check if it also solves your problem ? Thank you.
>>> Best regards,
