[Gdal-dev] problem compiling png in daily build
Sophia Parafina sophia.parafina at ionicenterprise.com
Wed Sep 12 13:51:05 EDT 2007
I'm trying to compile the gdal-svn-trunk-2007.09.12.tar.gz and I get
these errors while compiling:
gcc -c -DPNG_NO_GLOBAL_ARRAYS -Ilibpng -I../zlib
-I/home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12/port
-I/home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12/gcore
-I/home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12/alg
-I/home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12/ogr
-I/home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12/ogr/ogrsf_frmts
-I/home/sparafina/gdal-scripts/unix/install/include
-Wall -Wdeclaration-after-statement -fPIC -O2   libpng/pnggccrd.c -o
../o/pnggccrd.o
/tmp/ccNcUQGx.s: Assembler messages:
/tmp/ccNcUQGx.s:113: Error: suffix or operands invalid for `push'
/tmp/ccNcUQGx.s:114: Error: suffix or operands invalid for `push'
/tmp/ccNcUQGx.s:115: Error: suffix or operands invalid for `push'
/tmp/ccNcUQGx.s:116: Error: suffix or operands invalid for `pushf'
/tmp/ccNcUQGx.s:117: Error: suffix or operands invalid for `pop'
/tmp/ccNcUQGx.s:120: Error: suffix or operands invalid for `push'
/tmp/ccNcUQGx.s:121: Error: suffix or operands invalid for `popf'
/tmp/ccNcUQGx.s:122: Error: suffix or operands invalid for `pushf'
/tmp/ccNcUQGx.s:123: Error: suffix or operands invalid for `pop'
/tmp/ccNcUQGx.s:124: Error: suffix or operands invalid for `push'
/tmp/ccNcUQGx.s:125: Error: suffix or operands invalid for `popf'
/tmp/ccNcUQGx.s:143: Error: suffix or operands invalid for `pop'
/tmp/ccNcUQGx.s:144: Error: suffix or operands invalid for `pop'
/tmp/ccNcUQGx.s:145: Error: suffix or operands invalid for `pop'
make[3]: *** [../o/pnggccrd.o] Error 1
This seems to be a problem with 64bit gcc on AMD64.  Here is my compiler
info:
Reading specs from /usr/lib/gcc/x86_64-redhat-linux/3.4.6/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info --enable-shared --enable-threads=posix
--disable-checking --with-system-zlib --enable-__cxa_atexit
--disable-libunwind-exceptions --enable-java-awt=gtk
--host=x86_64-redhat-linux
Thread model: posix
gcc version 3.4.6 20060404 (Red Hat 3.4.6-3)
I tried to get around the problem by adding -DPNG_NO_ASSEMBER_CODE to
the CPPFLAGS in the png make file, but I get this error:
-L/home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12
-lgdal -I/home/sparafina/gdal-scripts/unix/install/include      -lz  -lm
-lrt -ldl  -L/home/sparafina/gdal-scripts/unix/install/lib  -L/usr/lib64
-lcurl -L/usr/kerberos/lib -L/usr/kerberos/lib64 -lssl -lcrypto
-lgssapi_krb5 -lkrb5 -lcom_err -lk5crypto -lresolv -ldl -lz
-lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lresolv -L/usr/kerberos/lib
-L/usr/kerberos/lib64 -lidn -lssl -lcrypto -lssl -lcrypto -lgssapi_krb5
-lkrb5 -lcom_err -lk5crypto -lresolv -ldl -lz -lz  -o gdalinfo
/home/sparafina/gdal-scripts/unix/build/gdal-svn-trunk-2007.09.12/libgdal.so:
undefined reference to `DGN2IEEEDouble(void*)'
undefined reference to `AVCBinReadClose'
undefined reference to `AVCBinReadOpen'
undefined reference to `AVCBinReadNextTableRec'
undefined reference to `png_mmx_support'
collect2: ld returned 1 exit status
make[2]: *** [gdalinfo] Error 1
I've compiled 1.4.2 without problems on the same box, so is there
something different in the daily build?
ophia
