[Gdal-dev] PostGIS and OGR - new try
    Brian Hamlin
    maplabs at light42.com
    Sun Sep 16 13:36:39 EDT 2007
I am new to PostGIS, and am trying out the dataset that Refractions has
posted for the FOSS4G Integration showcase. In the main foss database
there is a table called border.
The spatial_ref_sys for that database calls out a projection "NAD83 /
BC Albers"...
If I run,    ogr2ogr -f KML t.kml PG:dbname=TheRightName border
a KML file is produced, but the coordinates of the linestring are not
converted to Google Earth projection. The psatial_ref_sys is not
'automagically' detected.
ogr2ogr -s_srs NAD83 xxxx
still not usable results ?
ogr2ogr -s_srs NAD83 -t_srs WGS84 xxx
still no good
   Since the output of KML will always be in the projection GE uses,
should -t_srs be necessary?  Perhaps I am completely missing something
basic?
thanks in advance
  -Brian /darkblueB
