[Gdal-dev] Import Gdal
Roger André randre at gmail.com
Tue Sep 18 15:53:42 EDT 2007
Hi Gus,
Did you install Python and GDAL separately?  In the past when I've
installed GDAL independently, I've always had to specify that Python
is present, and enable support within GDAL for it.  Here is a link to
what appears to be a Windows executable that contains GDAL and Python
2.4 together - http://www.gdal.org/dl/win32/Python_GDAL-1.4.2.win32-py2.4.exe.
Roger
On 9/18/07, Gustavo Ces <g.ces at pettra.es> wrote:
> Hi all,
>     I´m newbie in Python so perhaps this problem is just a silly one. I´ve
> installed Python 2.4 and Gdal for this version ( executed de install
> software). When i try to import gdal module the GUI writes:
> Traceback (most recent call last):
>   File "<pyshell#1>", line 1, in -toplevel-
>     import gdal
>   File "E:\Python24\Lib\site-packages\gdal.py", line 191,
> in -toplevel-
>     import _gdal
> ImportError: DLL load failed: No se puede encontrar el módulo especificado.
> I don´t know what i have to do. Perhaps i had to do anything else.
> Thanks in advance
> Gus
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
