[Gdal-dev] Cs2cs input from file in Windows
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Thu Sep 20 13:45:35 EDT 2007
Jukka,
>I tried:
>C:\warmerda>more < input.txt
>-10 33
>C:\warmerda>cs2cs +proj=utm +zone=11 +datum=WGS84 < input.txt
>121d29'19.801"W 0d0'1.072"N 0.000
>This is with FWTools 1.3.7 for windows.  How did you results
>differ?
Strange, now cs2cs from just the same FWTools 1.3.6 version does accept my text file. The computer is not the same nor is the text file, so I must check my original case again tomorrow. Perhaps I learn something. Anyhow, now I get what I was waiting for:
FWTools1.3.6>more <input.txt
27 60
FWTools1.3.6>cs2cs  +proj=latlong +datum=WGS84 +to +proj=tmerc +lat_0=0
+y_0=0 +lon_0=27 +x_0=3500000 +k=1.000000 +ellps=intl +towgs84=-90.7,-106.1,
-119.2,4.09,0.218,-1.05,1.37 +units=m  input.txt
3500169.46      6654204.30 -23.67
-Jukka Rahkonen-
