[Gdal-dev] Re: GDAL's Python Identity Crisis (was Re: Import Gdal)
    Christopher Barker
    Chris.Barker at noaa.gov
    Fri Sep 21 00:59:57 EDT 2007
Howard Butler wrote:
> This is something that Frank is probably sick of me whining about.
Well, I, for one, am glad someone else is whining!
>  I'm
> willing to make the changes, but the consequence of doing so is we have
> to suck up the testing, question answering, and other grief a change
> like this will likely cause.  Can you do that with me?
Sure I'd be glad to help.
> I think we
> should only do this for the next-gen bindings,
I agree, though it might be better from a confusion stand point to have
them both the same -- I'm really not sure.
> The other issue is if we namespace the Python GDAL packages, what do we
> pick for a name?
Darn -- why are they different?
Anyway, I vote for package name gdal, with modules gdal, osr, ogr. So
you could do:
from gdal, import gdal, osr, ogr
(to convert from old code).
However, I did have an idea about covering the transition by having the
old names be small modules that raised a deprecation warning, then
imported everything from the new package (did I post that idea on the
list? I thought so). However, if we wanted to do that, then we couldn't
have a package "gdal", and a module "gdal" in the same place, so we'd
need to use another name: maybe osgeo, like C#, (why does Java use
"org"? that's odd.)
Anyway, the name is the least of my concerns.
Are you going to FOSS4G next week? I was thinking of working on this at
the sprint.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
