[Gdal-dev] .hdr labelled binary float raster
Tue Sep 25 21:29:06 EDT 2007
On 9/25/07, Bborie Park <bkpark at ucdavis.edu> wrote:
> C:\Documents and Settings\dustymugs\Desktop\TOPS>gdalinfo -mm
> TOPSTMAX.CA1KM.20070924.flt
> Driver: EHdr/ESRI .hdr Labelled
> Size is 738, 1203
> Coordinate System is `'
> Origin = (-2037330.654000000100000,-39280.983000000007000)
> Pixel Size = (1000.000000000000000,-1000.000000000000000)
> Corner Coordinates:
> Upper Left  (-2037330.654,  -39280.983)
> Lower Left  (-2037330.654,-1242280.983)
> Upper Right (-1299330.654,  -39280.983)
> Lower Right (-1299330.654,-1242280.983)
> Center      (-1668330.654, -640780.983)
> Band 1 Block=738x1 Type=Byte, ColorInterp=Undefined
>      Computed Min/Max=0.000,255.000
>    NoData Value=-9999
> When I import the raster with the ESRI header to ArcInfo, the min and
> max ranges are correct.
Bborie,
I'm not sure how arc/info decides that these files are floating
point, but GDAL needs the keyword NBITS with the value 32
and the keyword PIXELTYPE with the value FLOAT to recognise
an EHDR dataset as being floating point.
I believe this is causing the issue you see.
Best regards,
