[Gdal-dev] Angular or linear coordinates for a shapefile
Wed Sep 26 02:08:51 EDT 2007
On 9/25/07, Dan Homerick <danhomerick at gmail.com> wrote:
> Hello List,
> This probably something of a naive question -- please don't hesitate to
> point out what "should be obvious."
> I'm creating polygon-filled shapefiles using data extracted from a geotif.
> To do this, I'm using the OGRLinearRing::SetPoints() method and then adding
> the ring(s) to a polygon.
> My question is, what coordinate system should I be setting the points with?
> I want the resulting shapefile to still be georeferenced. The way I see it,
> I have 3 options, one of which is clearly wrong:
> 1. Pixel/Line coordinates from the image. (wrong)
> 2. Linear geo coords, resulting from GDALApplyGeoTransform.
> 3. Angular geo coords, resulting from something like:
> OGRSpatialReference* m_TargetSRS = m_SourceSRS.CloneGeogCS();
> m_LinearCoordToAngCoord =
> OGRCreateCoordinateTransformation(
>                                               &m_SourceSRS,
>                                               m_TargetSRS
> m_LinearCoordToAngCoord->Transform(...)
> where m_SourceSRS is set from the GeoTiff.
> Will my shapefiles be properly georeferenced if I use the second method (and
> a .prj file is used)?
Dan,
Yes
>  Will the be properly georeferenced if I use the third (without a .prj
> file)?
They won't be *properly* georeferenced, but they could still
be considered georeferenced with an implicit coordinate system.
But the third method with a .prj containing the geographic
coordinate system would be properly georeferenced.
> Also, what's the correct names for the "linear geo coords" and "angular geo
> coords"?
"linear geo coords" = Project Coordinate System (PROJCS)
"angular geo coords" = Geographic Coordinate System (GEOGCS)
Best regards,
