[Gdal-dev] Problems retrieving z-values
Thu Sep 27 11:16:18 EDT 2007
On 9/26/07, tjansson <tommy.jansson at kongsberg.com> wrote:
> I am writing a library which reads S-57 files (of type *.000) and loads
> selected geometies into a custom class structure. The files are read and
> content handled using the OGR Simple Features Library for C++.
> As far as I have understood the various geometries are divided into two
> categories; 2D geometry types with XY-data, and 2.5D geometry XYZ-data.
> I am interested in geometries of type 2.5D (i.e with XYZ-data). In my code
> there is a function which parses geometry objects using a switch that check
> the geometry type (and handles it accordingly). I have read several maps
> with success (e.g. downloaded from NOAA), except that the Z-value is always
> set to 0 (zero). I've also noticed - when debugging - that the switch never
> hits on geometry type "wkbPoint25D" (or any other 2.5D type), which might
> explain the Z-value.
> Is the code i have written doing something wrong, because I never get a hit
> on any 2.5D types, or are the maps I have downloaded the cause (because they
> don't contain any 2.5D types)?
Tommy,
I think SOUNDG features the the main feature type in S-57
that actually returns 3D geometries, and they are normally
of type wkbMultiPoint25D.
I *think* (memory grows foggy) that most other geometries
you would think might be 2.5D - like depth polygons - just
keep the depth as an attribute.
Best regards,
