[gdal-dev] GDAL C# bindings and TIFF read projection trouble
Tue Apr 1 14:04:35 EDT 2008
Kerry Halligan wrote:
> Tamas and Frank,
> Thank you both for your replies.  I tried Tamas' suggestion and found the
> same problem.  I suspect that my problem is that it is not finding the
> correct CSV files as Frank suggested.  Because I am using the prebuilt
> binaries from FWTools, I have been copying the DLL files (e.g., gdal_csharp)
> into my c# application directories (debug/release) but linking to support
> files by simply including the appropriate directories (in my case:
> C:\Program Files\FWTools1.3.9\bin\;C:\Program Files\FWTools1.3.9) in the
> PATH environment variable.  I am guessing that this works fine for libraries
> but does not help it locate the CSV files, is that correct?
Kerry,
That is correct.
> What is the
> right way to tell a C# application where/how to find these files?  My
> apologies if this is a super basic question or has been answered repeated on
> this list - I am obviously new to this...
You could define them in the system environment (using the GDAL_DATA
and perhaps the GEOTIFF_CSV environment variables).  It should also
be possible to call the GDALSetConfigOption() function (I'm not sure
what the C# binding is called) to set these values.  This should be
one of the first things you do with GDAL - before the first GDALOpen()
at least.
In C/C++:
   CPLSetConfigOption( "GDAL_DATA", "C:\\gdal\\data" );
The GDAL plugin loader also automatically searches for plugins in
a directory relative to the .exe.  This same sort of .exe relative
searching might make sense for GDAL_DATA, at least on win32 where it
is easy to find the .exe path.  I'm not sure if this sort of thing
works smoothly in .net applications or not.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
