[gdal-dev] updating a HFA image
Limei Ran lran at unc.edu
Tue Apr 1 14:56:41 EDT 2008
Hi:
I opened an HFA image and got a band from it (only 1 band image).  I
read a region from the band and update the band with the updated array.
But, for somehow, I can not view the updated HFA image in arcGIS due to
building pyramids failed.  Could you give me some ideas about what may
go wrong?  Here are codes related:
     //open the new copied data set for the following updating
     poRDataset = (GDALDataset *) GDALOpen( newFileName.c_str(),
GA_Update );
     if( poRDataset == NULL )
         printf( "Open raster file failed: %s.\n", newFileName.c_str() );
         exit( 1 );
        poBand = poRDataset->GetRasterBand( 1 );  // band 1
        GByte *poImage = (GByte *)
CPLCalloc(sizeof(GByte),c_nXSize*c_nYSize);
        if ( (poBand->RasterIO(GF_Read, c_col1-1,c_row1-1,c_nXSize,c_nYSize,
               poImage,c_nXSize,c_nYSize,GDT_Byte,0,0)) == CE_Failure)
              printf( "Error: reading band 1 data error from image i:
              CPLFree (poImage);
              exit( 1 );
        for (int k=0; k<c_nXSize; k++)
               if (poImage[k] == 127)
                  poImage[k] = 0;
           //write back to the current image i
           if ( (poBand->RasterIO(GF_Write,
              printf( "Error: Writing band 1 data error to image i:
              CPLFree (poImage);
              exit( 1 );
           poRDataset->FlushCache();
           GDALClose( (GDALDatasetH) poRDataset );
           CPLFree (poImage);
Thanks,
Limei
