[gdal-dev] gdal_merge.py -separate failing to create RGB
mattia mattia.parigiani at gmail.com
Tue Apr 1 19:44:40 EDT 2008
Hi folks,
I have a problem trying to create RGBs with the gdal_merge.py utility...
Mainly I have some images that I have extracted from HDF4 SDSs and processed
in TIFF format using ImageMagick...
Now a sample image as the following gdalinfo output:
*mattia at mattia-laptop:~/Desktop/rgb$ gdalinfo t2.tif
Driver: GTiff/GeoTIFF
Files: t2.tif
Size is 2708, 9340
Coordinate System is `'
Metadata:
 TIFFTAG_DOCUMENTNAME=AMOD02HKM20070104021601_0_1_band_2_out.tif
 TIFFTAG_SOFTWARE=ImageMagick 6.3.8 02/18/08 Q16 http://www.imagemagick.org
 TIFFTAG_XRESOLUTION=72
 TIFFTAG_YRESOLUTION=72
 TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
 INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 9340.0)
Upper Right ( 2708.0,    0.0)
Lower Right ( 2708.0, 9340.0)
Center      ( 1354.0, 4670.0)
Band 1 Block=2708x1 Type=UInt16, ColorInterp=Gray*
The file size (for the three images I am trying to merge) is about 50MB..
As you can see its a 16 bit image..
if I run something like:
* gdal_merge.py -separate t1.tif t2.tif t3.tif -o out.tif*
The output image out.tif is still a greyscale where 2 of the bands are
somehow "not recognized"...
The gdalinfo on the output tif is:
*Driver: GTiff/GeoTIFF
Files: out.tif
Size is 2708, 9340
  INTERLEAVE=PIXEL
Corner Coordinates:
Band 2 Block=2708x1 Type=UInt16, ColorInterp=Undefined
Band 3 Block=2708x1 Type=UInt16, ColorInterp=Undefined
Does it have to do with the fact that its a 16 bit image and gdal_merge.py
doesn't support it?
With the fact that ImageMagick has corrupted something ?
Or what exactly is the issue?
Thanks in advance
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080401/9a49daa8/attachment.html
