[gdal-dev] build error on latest svn trunk
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Fri Apr 4 12:01:22 EDT 2008
On fc7, with:
./configure --with-png --with-libtiff=internal --with-geotiff=internal
--with-jpeg --with-xerces --with-geos=no
--with-pg=/usr/local/pgsql/bin/pg_config
--with-mysql=/usr/bin/mysql_config --with-sqlite --with-curl=/usr/bi
n/curl-config --with-python --with-expat --with-perl
ogrpgtablelayer.cpp: In member function 'virtual OGRErr
OGRPGTableLayer::DeleteFeature(long int)':
ogrpgtablelayer.cpp:706: warning: format '%d' expects type 'int', but
argument 4 has type 'long int'
ogrpgtablelayer.cpp: In static member function 'static CPLString
OGRPGTableLayer::EscapeString(PGconn*, const char*, int, const char*)':
ogrpgtablelayer.cpp:839: error: 'PQescapeStringConn' was not declared in
this scope
make[3]: *** [../o/ogrpgtablelayer.o] Error 1
make[3]: Leaving directory
`/home/tkralidi/foss4g/gdal/trunk/gdal/ogr/ogrsf_frmts/pg'
make[2]: *** [pg-target] Error 2
make[2]: Leaving directory
`/home/tkralidi/foss4g/gdal/trunk/gdal/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory `/home/tkralidi/foss4g/gdal/trunk/gdal/ogr'
make: *** [ogr-target] Error 2
