[gdal-dev] Re: [GRASS-dev] Updated OGR/SHAPELIB based DBF driver crashing with GRASS SVN
Wed Apr 9 13:01:44 EDT 2008
Glynn Clements wrote:
> Markus Neteler wrote:
>> after syncing (as regularly) the DBF driver from SHAPELIB embedded
>> in OGR, we face the problem that it no longer works with older GDAL
>> versions than current SVN:
>> http://trac.osgeo.org/grass/ticket/110
>> I don't know what to do. In essence, I don't want to fork our version
>> from yours.
>> Any ideas?
> I suggest using a "stub" implementation of the I/O hooks. E.g.:
> typedef struct {
>     FILE*     (*FOpen) ( const char *filename, const char *path);
>     size_t    (*FRead) ( void *p, size_t size, size_t nmemb, FILE* file);
>     size_t    (*FWrite)( void *p, size_t size, size_t nmemb, FILE* file);
>     long      (*FSeek) ( FILE* file, long offset, int whence );
>     long      (*FTell) ( FILE* file );
>     int       (*FFlush)( FILE* file );
>     int       (*FClose)( FILE* file );
>     void      (*Error) ( const char *message );
> } SAHooks;
> static void error_fn( const char *message )
>     G_fatal_error("%s", message);
> static void SASetupDefaultHooks( SAHooks *psHooks )
>     psHooks->FOpen  = fopen;
>     psHooks->FRead  = fread;
>     psHooks->FWrite = fwrite;
>     psHooks->FSeek  = fseek;
>     psHooks->FTell  = ftell;
>     psHooks->FFlush = fflush;
>     psHooks->FClose = fclose;
>     psHooks->Error  = error_fn;
Folks,
I'm just trying to catch up on this topic.  There is already a stdio
based implementation in shapelib itself.  I have attached it,and it is
normally in a file called safileio.c.
I'm afraid I'm uncertain of the implications of mixing the Shapelib 1.3
code with GDAL's using Shapelib 1.2.  It seems potentially like it could
be a problem.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Type: text/x-csrc
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080409/f91cd506/safileio.bin
