[gdal-dev] demtools patch.
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Apr 9 19:09:37 EDT 2008
Hi rezso,
 >   Matt, I recall over demtools a bit, ... talking with gdal Folks
 > to see that there is a way to make demtools part of gdal.
I didn't see any chatter go by after your message. The best thing to do
so that your contribution isn't lost in the shuffle is to create a
feature proposal ticket at http://trac.osgeo.org/gdal/ to include demtools
I see from a comment to http://www.perrygeo.net/wordpress/?p=7 that MS4W
is including demtools by default now, so it probably is a good idea to
put this in with the rest of the utilities.
cheers,
(another) matt
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
rezso at rdsor.ro wrote:
> Hello Matt, Folks,
>   Matt, I recall over demtools a bit, i mailed you few weeks ago
> with license issue and thanks for that, and talking with gdal Folks
>   This would imply license change in favor of gdal and small
> re-work over the code, so you can further comment here.
>   For preliminary i would like to offer a small patch wich get
> demtools closer to gdal.
> patch does:
>   - fix gcc43 complie issue and warnings (olso do VC2008)
>   - get rid of stingtoken.h and use gdal internals for this
>   - add progressbar as gdal tools does using gdal API
>   - use more gdal internals for for some fopen/fclose handling
>  Patch attached, plus a smal example.sh script for better see
> what this tool can do. It uses ImageMagick to merge two tiles
> and listgeo to restore spatial data.
>  Let me know how can i further polish to be more gdal compliant, if Matt
> accept the proposal.
>   For those who don't know anything about subject i re-post the link:
>   http://perrygeo.googlecode.com/svn/trunk/demtools/
> Best Regards,
> Cristian.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
