[Gdal-dev] special case occurs at reprojection with gdalwarp
la cipola la_cipola at yahoo.de
Tue Apr 15 07:48:32 EDT 2008
Hi List!
I am warping images using gdalwarp (lat/lon into mercator projection).
There are two cases
Case 1: source image 257x257 --> result image 257x257 (OK)
Case 2: source image 256x257 --> result image 256x257 (not OK, having a
Black Stripe on the right instead of Imageinformation)
I know, that ratios change in warping process but in Case 2
there is missing some imageinformation in spite of correct
dimensions.
Does anybody know why there is missing Imageinformation in
Case 2??
Thanks!
Mike http://www.nabble.com/file/p16700106/257x257px_correct.jpg
http://www.nabble.com/file/p16700106/256x257px_incorrect.jpg
View this message in context: http://www.nabble.com/special-case-occurs-at-reprojection-with-gdalwarp-tp16700106p16700106.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
