[gdal-dev] Design/Re-Design consideration
Stephen Woodbridge woodbri at swoodbridge.com
Thu Apr 17 11:13:48 EDT 2008
Hi all,
I really like gdal and ogr. I can't say I use them all the time, but
they work and do the job when I need them and I would be lost without
them on some jobs. So Thanks and keep up the good work.
I want to toss out an idea that I think would make gdal/ogr better. This
comes from my frustration with the fact that as more formats are
supported, the more system library dependencies that are required to
install it. I was horrified when I went to build mapserver with wfs
support and I only use shapefiles on postgis layers that I had to
install gdal and that pulled in some 20-30 other system packages!!!!
This is insane from my perspective. I don't need any of those packages
for the work I'm doing, maybe mapserver should not require gdal for wfs,
but I'm sure there is a good reason for that choice.
Regardless, The idea that I want to offer is that I think it would be
very cool from a packaging point of view if gdal/ogr could take a page
from the PHP book and configure a directory of runtime loadable modules.
There would be a base package and then each format or group of formats
would be loaded at runtime if it existed in the modules directory. In
your ./configure script you could select what optional modules you want
to build like --with-mod=all or --with-mod=gtif or these might be
automatically figured out from the libraries installed or requested.
Then packaging would be based on the base package and and any optional
format packages you want to install and each format package would have
its own library dependencies. This would greatly simplify the growing
tangle of system library and packaging dependencies and make things more
modular from the users perspective.
Its an idea, maybe not well thought out, it probably involves a lot of
work on someones part. It is offered in the hopes of making gdal/ogr
better and more accessible from users and sysadmin's perspective.
Discuss amongst yourselves.
Thanks,
   -Steve W
