[gdal-dev] SRTM30+ Version 3.0 as GeoTIF?
Rich Signell rsignell at usgs.gov
Thu Apr 17 16:41:34 EDT 2008
Frank,
>  I produced the merged SRTM30+ geotiff that was on geotorrent.org.  I
>  believe I recently scrubbed the directory where I did this work.  I
>  had implemented it by writing a small python script to create a .hdr
>  or something similar for each file.
>  It is my understanding that the relatively new SRTM driver in GDAL
>  should support srtm files directly, so I think you could use it with
>  gdal_merge.py to create an SRTM mosaic directly.
The new SRTM driver in GDAL reads the 1 and 3 sec SRTM, but not the
30sec format, I believe.  But not a problem -- I didn't notice before
that there is another directory at the SRTM30+ site with ERMapper
headers, which combined with the raw data files works just fine with
GDAL.   So it will be easy to make the tiles and assemble with
gdal_merge.py.
Thanks,
Rich
Dr. Richard P. Signell (508) 457-2229
USGS, 384 Woods Hole Rd.
Woods Hole, MA 02543-1598
