[gdal-dev] question about ogr
Tamas Szekeres szekerest at gmail.com
Sat Apr 19 12:42:20 EDT 2008
Mateusz,
The dependencies of the gdal dll cannot be identified very well using
the Walker, since many of the dependent libaries are linked at
run-time. I'd rather use a file monitoring tool (like SysInternals
filemon) to see the expected locations of the files. But in this
particular case I'm not totally sure if this is the problem without
having the complete exception message.
Best regards,
Tamas
2008/4/19, Mateusz Loskot <mateusz at loskot.net>:
> Tamas Szekeres wrote:
> > Could you post the entire error message here? My best guess at this
> > point is that some of the required dll-s couldn't be loaded at
> > run-time.
>  Tamas,
>  AFAIR, it should be also feasible to use Dependency Walker to test if all
> C# dependencies are findable. Am I correct?
>  Cheers
>  Mateusz Loskot
>  http://mateusz.loskot.net
>  _______________________________________________
>  gdal-dev mailing list
>  gdal-dev at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
