[gdal-dev] MapServer's image quality stinks serving up these NOAA NRCs
Vincent Schut schut at sarvision.nl
Mon Apr 21 04:19:54 EDT 2008
Frank Warmerdam wrote:
> Gregor Mosheh wrote:
 >> * Color depth: gdalwarp on the KAPs generates 8-bit palleted TIFFs.
 >> That may not be the best for quality.
^^This point might be your main issue.
As Frank mentioned it's a bit hard for us to guess about the source of
your problem without actually seeing those images, but my first guess
would be: don't use palette images, use rgb or rgba. You can control
this with a mapserver output file format parameter, ('OUTPUTTYPE'? don't
know anymore exactly what it's called, but it should state that you want
something like PNG24 (24bit png's) or the like, not png8 or gif or
whatever image that uses colortables/palettes internally). Otherwise,
mapserver will semi-intelligently (read: bluntly) map your nice rgb
input colors to some more-or-less fitting palette, thus greatly reducing
output image quality (but also reducing file size, thus image loading
times). If your output map is tiled (which it usually is if you use an
interface like OpenLayers), mapserver will even use different palettes
for each tile, which will make the overall output image look even
stranger. So I'd say: first make sure you have mapserver to output rgb
images, like jpg or 24bit png's. If image quality is still crap then,
come back and call again :-)
Good luck!
Vincent.
