[gdal-dev] Ogr2ogr, shp-dgn conversion
Wed Apr 23 09:06:03 EDT 2008
Olof Landahl wrote:
> Hi,
> I'm using ogr2ogr (included in gdal) to convert a shapefile to
> Microstation DGN format. The conversion does the job, except that
> polygons and line strings with too many (38) vertices are converted into
> complex shapes. What is the reason for this?
> When I open the DGN-file in Microstation the complex shapes are visible
> but not possible to select or edit without a lot of work with special
> tools. Can I do something in the conversion with ogr2ogr to prevent it
> from creating complex shapes or to make the complex shapes selectable?
Olof,
I don't recall the exact details any more, but I presumably did this
because there was a limit on the length of regular lines in Microstation.
I'm not aware of anything you can do about this.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
