[gdal-dev] Ogr2ogr Pgeo to SQL?
    Dane Springmeyer
    blake at hailmail.net
    Wed Apr 23 14:55:46 EDT 2008
Hi Frank,
Thanks for the feedback. I am ultimately importing the data with
Geodjango python bindings to OGR and have not gotten them to work with
GML yet, but did try that.
I had not considered SQLite, which is a great idea since Django
supports that format as an alternative to PostgreSQL.
Thanks!
Dane
On Apr 23, 2008, at 9:11 AM, Frank Warmerdam wrote:
> Dane Springmeyer wrote:
>> Hi,
>> I've been using the PGeo driver on a windows machine to convert
>> ESRI geodatabases/Access Databases (.mdb) to shapefiles (I have not
>> got the driver working yet on linux). Now, I'd like to send
>> directly to PostgreSQL (so all of my column names are not
>> truncated), but I run my Postgres Server on a separate, non
>> networked linux machine. As such, I'd like to use Ogr2ogr to create
>> intermediate output, ideally a sql insert statement like shp2pgsql
>> does.
>> My sense is that the ogr2ogr utility is not built this way (there
>> is no SQL format specifically) and I'd be best off to actually
>> spend the time to network my machines. Anyone have suggestions
>> about other approaches? Perhaps there is a crafty way to capture
>> the insert statement ogr2ogr is making and write it to a file?
> Dane,
> There is no mechanism provided for capturing the Postgres insert
> statements.
> I would suggest solving the networking problem.
> But if that is impractical, you could also look at using more
> expressive
> intermediate file formats like GML, SQLite for the intermediate files.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
