[gdal-dev] Motion: To adopt RFC 23: Unicode Support in OGR
Fri Apr 25 15:23:23 EDT 2008
Folks,
I have made a small amendment to the RFC, adding a new layer level
capability test for whether the string attributes are clearly in UTF-8.
OLCStringsAsUTF8 Capability Flag
Some drivers (ie. CSV) can effectively not know the encoding of their inputs.
Therefore, it isn't always practical to turn things into UTF-8 in a guaranteed
way. So, the new layer level capability called "StringsAsUTF8" represented with
the macro "OLCStringsAsUTF8" will be testable at the layer level with
TestCapability?(). Drivers which are certain to return string attributes as
UTF-8 should return TRUE, while drivers that do not know the encoding they
return should return FALSE. Any driver which knows it's encoding should convert
to UTF-8.
I'll extend the voting till Tuesday to account for this mid-vote edit though
I don't think it should be very contentious.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
