[gdal-dev] VMAP Problems - Correct Posting.
    Courtney Schitka
    c.schitka at gmail.com
    Fri Apr 25 18:18:23 EDT 2008
That's the problem. is that using ogrinfo or ogr2ogr I can open the
datasource on the command line just as was described.
 However trying to open the data source. in an application I am working on
using syntax like this.
Driver* pDriver = OGRSFDriverRegistrar::Open(  path to datasource ).
OGRLayer* pLayer = pDriver->GetOgrLayer(0) //Could have gotten one by name
but for simplicity.
pLayer is != 0 //So I assume I am getting a valid layer back.
However when I try and get the features for this layer I always get the
error 2 end of selection message. The reason my URI was in the format it was
in my last post is that.
ogrdogdidatasource.cpp in gdal. Specifies when opening a vmap data source it
needs to be in the format
gltp://<hostname>/<format>/<path_to_dataset>[:<layer_name>:<Family>] ln 93
If open the URI in the format Martin suggested from the command line then it
work and I get features out. But trying to do it progmatically as shown
above I can't get any features out, which infact is the blocking issue here
for me.
Thanks for any kind help.
Court
 I get an opened data source and a pointer to the driver, from which I can
then as for a layer. However when I try and
On Fri, Apr 25, 2008 at 5:38 PM, Martin Spott <Martin.Spott at mgras.net>
wrote:
> Martin Spott wrote:
> > [...] and don't forget to put quotes around special characters.
> Sorry, I presume this counts only when running on the command line,
> Martin.
>  Unix _IS_ user friendly - it's just selective about who its friends are !
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080425/0d0c18f8/attachment.html
