[gdal-dev] netcdf option build error
Jeshua Lacock jeshua at OpenOSX.com
Tue Apr 29 11:44:27 EDT 2008
On Apr 29, 2008, at 8:45 AM, William Kyngesburye wrote:
> What about HDF4?  If you are compiling GDAL with that as well, make
> sure to use the --disable-netcdf option in HDF4.
That seems to help some, as now I only get one error:
GDapi.c: In function 'GDsdid':
GDapi.c:10873: error: 'MAX_VAR_DIMS' undeclared (first use in this
function)
GDapi.c:10873: error: (Each undeclared identifier is reported only once
GDapi.c:10873: error: for each function it appears in.)
GDapi.c:10873: warning: unused variable 'dims'
make[4]: *** [../../o/GDapi.o] Error 1
make[3]: *** [lib-hdfeos] Error 2
make[2]: *** [hdf4-install-obj] Error 2
make[1]: *** [frmts-target] Error 2
make: *** [gdal] Error 2
Any ideas?
Thanks,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
