[gdal-dev] netcdf option build error
William Kyngesburye woklist at kyngchaos.com
Tue Apr 29 17:48:59 EDT 2008
On Apr 29, 2008, at 4:20 PM, Jeshua Lacock wrote:
> On Apr 29, 2008, at 2:39 PM, William Kyngesburye wrote:
>> You should probably add __i386__ to the define tests here.
> I am not sure if I fully understand, should I add to line 66:
> 	&& !defined(__i386__)
> Or if that is not correct, can you email me a patch?
That's it.
And it's an odd one too, since the HDF4 configure detects endianess
and adds a -DSWAP, if needed, to all makefiles.  Must be leftovers
from the previous version ;)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
