[gdal-dev] read/write ungenerate files?
Craig Miller craig.miller at spatialminds.com
Wed Apr 30 13:52:25 EDT 2008
Back in the day Sol Katz had some code up on his FTP site.  If I remember
correctly there is some in the AVCBin OGR driver.
I have this extremely vague recollection of there once being a "generate" or
"arc export" OGR driver that used to contain both the code for reading E00
files and Arc Coverages.  Maybe poke around the OGR source tree?
Craig
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Matt Wilkie
Sent: Wednesday, April 30, 2008 9:42 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] read/write ungenerate files?
Hello,
Does anyone know of any read/write code for ArcInfo UNGENERATE files?
I know GRASS does, but I need to find or write a command line script to
change elevation values so using GRASS is not really an option here.
thanks in advance,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.6/1407 - Release Date: 4/30/2008
11:35 AM
No virus found in this outgoing message.
Checked by AVG.
11:35 AM
