[gdal-dev] VMAP Issues.
Wed Apr 30 14:59:51 EDT 2008
Courtney Schitka wrote:
> Hi Frank,
> I suspect that what is happening is that the VMAP data source is being
> opened for writing instead of for reading. After debugging here is why
> I've come to this conclusion.
> OGRDataSource* pOGRDataSource = OGRSFDriverRegistrar::Open(char
> *ptrDataSrc);
> This in turn goes through all the drivers until it comes to.
> int
> OGROGDIDataSource::Open
> So as I step through this code, with the debugger everything works like
> I would expect it to work.
> Then I come to this
> /* If an explicit layer was selected, just create that layer. */
> m_poCurrentLayer = NULL;
> I am selecting an explicit layer so I am bewildered at why this is set
> to NULL (On a side note I suspect this being null is the root of my
> problems).
Courtney,
Are you are specifying a layer name in the datasource name in
your program, and not doing the same when using ogrinfo?  That
is certainly a significant difference!  I didn't even know that
this layer name selection in the datasource name logic existed,
though I must have written it some 8-9 years ago.
Is there a reason you are doing this?  Why not just open the same
datasource name you use with ogrinfo, and then use GetLayer() or
GetLayerByName() to fetch the layer handle?
I see the explicitly named layer logic does not use cln_GetLayerCapabilities().
Perhaps there is a side effect of this difference.  The
cln_GetLayerCapabilities() in the OGDI API is actually a relatively recent
addition to the API.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
