[gdal-dev] failed to load NAD27-83 correction file
Lee Eschler hietokolob at gmail.com
Thu Aug 7 12:39:11 EDT 2008
Greetings,
I am trying to transform XY coordinates using Python.  I am using Python
2.4.1 on Windows XP Professional Service Pack 3.  Here is the code I am
using:
from osgeo import osr
#original SRS
sourceSR = osr.SpatialReference()
sourceSR.ImportFromEPSG(26712) #utm nad27 12n
#target SRS
targetSR= osr.SpatialReference()
targetSR.ImportFromEPSG(4301) #stateplane nad83 Utah north zone
#targetSR.ImportFromEPSG(26912)# utm nad 83 12n # Same results as (4301)
coordTrans =osr.CoordinateTransformation(sourceSR,targetSR)
x=423061.91
y=4524687.86
res=coordTrans.TransformPoint(x,y)
print 'x= %10.2f , y= %10.2f' % (res[0],res[1])
I get x= -1.95, y= 0.71
should be x = 196359.35 y = 1885770.43
The error returned is " ERROR 1: failed to load NAD27-83 correction file".
I extracted the PROJ 4.4.6 WIN32 Binaries into my C:\Program Files
directory. Added C:\Program Files\proj\bin to the end of my System Path
environment variable.
Added a System environment variable called PROJ_LIB with the value of
C:\Program Files\proj\nad
I am not sure what I have done wrong and was hoping someone could point me
in the right direction.
Thanks
Lee Eschler
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080807/bd29746a/attachment.html
