[gdal-dev] Minimalist Windows binaries (OGR)
Philippe Kruschitz kruschitz at grid-it.at
Fri Aug 8 04:06:47 EDT 2008
Hi Dejan,
Thanks for the explanation. I wasn't aware that the ESRI projections
definitions were modified that often. As I'm working with only a couple
of projections in this project, I'll write the PRJ files manually (and
hope they don't change those definitions in a near future...)
Regards,
Philippe
> However, I do see that a whole database of PRJ files has to be
> incorporated and matched with a projection database in FW Tools/GDAL,
> since the keywords for different PCS, GCS, DATUMS, SPHEREOIDS and other
> parameters have to keep the same/identical (they are then stored e.g.
> into SDE repository directly after importing a SHP into a GDB, so you
> might have different SRID entries for the same Spatial references as you
> might have different PRJ files pointing to the same spatial references,
> with the same/similar parameters).
> However, ESRI is updating its projection database quite often (even
> through the SP releases), so reconciling both database could be a huge
> task. Not being in sync with the ESRI DB can cause users using GDAL
> managed data at ESRI side some problems, especially when calling SRIDs
> or having multiple environments, different ESRI SW versions and updates
> installed.
> However, I would love to see that output files from GDAL have
> appropriate PRJ files with it, if this is feasible :-)
> Best regards,
> Dejan
