[gdal-dev] [GDAL 1.5.1] How to build and run GDAL 1.5.1 on windows
Tamas Szekeres szekerest at gmail.com
Fri Aug 8 06:57:55 EDT 2008
Cherif,
You have to create or use a host process which is loading and use the
gdal15.dll. Probably you can utilize one of the existing applications
like gdalinfo.exe or ogrinfo.exe have been compiled along with the
gdal project.
Best regards,
Tamas
2008/8/8 Cherif Oueslati <oueslati.cherif at gmail.com>:
> Hello every body,
> I found a problem to run the GDAL 1.5.1 in a MS Visual Studio 2003
> Environment, to test the implementation of a driver that i developed.
> The error appears when i would like to run the project and indicates that it
> is impossible to begin the debug because it's impossible to start the
> "gdal15.dll".
> Someone suggest to me to well define the "environment variables".
> Can you tell me how could i run gdal 1.5.1 or how to set the "environment
> variables" inside the visual studio it self.
> With all my gratitude.
> Cherif.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
