[gdal-dev] Problem importing osgeo module in Python
Christopher Barker Chris.Barker at noaa.gov
Fri Aug 8 15:01:35 EDT 2008
Roger André wrote:
> $ python
> Python 2.3.4 (#1, Dec 11 2007, 05:28:55)
> [GCC 3.4.6 20060404 (Red Hat 3.4.6-9)] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
>  >>> from osgeo import gdal
> Traceback (most recent call last):
>   File "<stdin>", line 1, in ?
> ImportError: No module named osgeo
> --> Not good.
> Looking back through the make output, I see that the osgeo modules are
> being created and copied:
>     copying build/lib.linux-x86_64-2.3/osgeo/gdal.py ->
> /export/lib64/python2.3/site-packages/osgeo
> So I tried appending the location to the sys.path in Python to make the
> modules available,
that shouldn't be required -- site-packages should be on your sys.path
already. Is your python in /export/lib64/python2.3 ? Do you have more
than one python?
try:
$ which python
and maybe something like:
$ python
 >> import datetime 3 or any standard module
 >> print datetime.__file__
As a way to see where your python install is.
Also -- why python 2.3? that's getting pretty darn old!
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
