[gdal-dev] BuildOverviews (python) going nuts?
Vincent Schut schut at sarvision.nl
Mon Aug 11 06:35:37 EDT 2008
Hi folks,
is it just me, or is the BuildOverviews function behaving strange on you to?
I regularly call someDs.BuildOverviews("AVERAGE", [plist]) on my output
datasets (in swig python, that is). Until some time ago (can't tell
precisely, have been out of business for some time) this worked find.
However, currently I get the following errors:
ERROR 1: TIFFSetField:/home/mrp/modis/zandbak/vzaCorrectionTest.tif:
Cannot modify tag "Compression" while writing
Cannot modify tag "ImageWidth" while writing
Cannot modify tag "PlanarConfiguration" while writing
Cannot modify tag "BitsPerSample" while writing
Cannot modify tag "SamplesPerPixel" while writing
Cannot modify tag "PhotometricInterpretation" while writing
Cannot modify tag "SampleFormat" while writing
Cannot modify tag "TileWidth" while writing
Cannot modify tag "TileLength" while writing
ERROR 1: GTIFFWriteDirectory:Can not write tiles to a stripped image
Which is quite strange, because I am definitely sure that my image is a
tiled image. I have double-checked this with gdalinfo.
Calling gdaladdo afterward on the file works OK, though, so I suppose
something has changed in the swig/python wrappers...
Btw this is on linux, pretty recent gdal from svn (rev. 15069), bigtiff
enabled.
Cheers,
Vincent.
