[gdal-dev] Exporting line vertices to SHP using GDAL
D eloquence2 at gmail.com
Mon Aug 11 09:41:56 EDT 2008
I would like to export vertices from a 3D Geometry from Oracle Spatial (11g)
into an 2D ESRI Shapefile with a field "Z" that comes from the the 3D SDO
geometry.
Is is possible to do this using GDAL tools?
Any suggestions how to handle this, would be very helpful!
Thanks!
Dejan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080811/c975309e/attachment.html
