[gdal-dev] Exporting line vertices to SHP using GDAL
D eloquence2 at gmail.com
Mon Aug 11 09:54:51 EDT 2008
Dear Mateusz,
I was not clear enough. what I would need is exporting every single vertex
to a single point feature in a SHP.
If I am quessing, I can just define in OGR2OGR -NLT POINT and I will point
objects of every single vertex?
How do I fill in the atribute Z value for every single exported point
feature?
Thanks!
Dejan
On Mon, Aug 11, 2008 at 3:45 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> D wrote:
>> Hi,
>> I would like to export vertices from a 3D Geometry from Oracle Spatial
>> (11g)
>> into an 2D ESRI Shapefile with a field "Z" that comes from the the 3D SDO
>> geometry.
>> Is is possible to do this using GDAL tools?
> Dejan,
> You can use ogr2ogr utility with option -nlt, see this:
> http://gdal.org/ogr/ogr2ogr.html
> Best regards
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080811/141c9c3f/attachment.html
