[Gdal-dev] Tif file getting larger and larger
Fodder cryan at csse.com.au
Thu Aug 14 08:05:59 EDT 2008
Ah, dear, so if I want to frequently change values in TIF file, I basically
can't use compression as the file will quickly get larger than the
uncompressed version. Is this a fair comment?
Also, I've noticed that after 5-8 re-writes of the whole dataset (RasterIO
the whole grid from a buffer), the dataset seems to get corrupted anyway.
Maciej Sieczka wrote:
> Related?: http://trac.osgeo.org/gdal/ticket/1688 (some more info in a
> duplicate http://trac.osgeo.org/gdal/ticket/1689).
> Maciek
> Maciej Sieczka
> www.sieczka.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://www.nabble.com/Tif-file-getting-larger-and-larger-tp18976082p18980252.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
