[gdal-dev] OGRFeatureStyle update from version1.4.1 to 1.5.2;
wow 27949218 at qq.com
Sun Aug 17 00:31:48 EDT 2008
   When i tried to update my whole program from ver1.4.1 to 1.5.2, all worked well except the  OGRFeatureStyle  module. The function OGRStyleMgr::AddStyle() couldn't write the provided style name and style string right with ver1.5.2, but could run smoothly with version 1.4.1.
   My code :
 bool CBcgtDoc::CreateDefaultStyle(CString strTlbPath, int nType)
      OGRStyleTable oStyleTable;
      OGRStyleMgr   *poStyleMgr = new OGRStyleMgr(&oStyleTable);
      bool res;
      switch(nType)
          case 1:            //point
            res = poStyleMgr->AddStyle("@symbol", "SYMBOL(c:#00FF00,id:\"swS0\",s:1.0,l:1)");
            res = poStyleMgr->AddStyle("@label", "LABEL(c:#FFFF00,f:\"MS Gothic\",s:10px,t:\"\",l:1)");
            res = oStyleTable.SaveStyleTable(strTlbPath);
           break;
        case 2:              //line
            res = poStyleMgr->AddStyle("@symbol", "SYMBOL(c:#00FF00,id:\"swS0\",s:1.0,l:1)");//
            res = poStyleMgr->AddStyle("@label", "LABEL(c:#0000FF,f:\"MS Gothic\",s:10px,t:\"\",l:1)");//
            res = poStyleMgr->AddStyle("@line", "PEN(c:#FF0000,w:3px,id:\"swL0\",l:1)");//
           break;
       case 3:              //polygon
            res = poStyleMgr->AddStyle("@label", "LABEL(c:#FF0000,f:\"MS Gothic\",s:10px,t:\"\",l:1)");
            res = poStyleMgr->AddStyle("@brush", "BRUSH(fc:#C0C0C0,id:\"swR0\")");
           break;
      default:
           break;
  if(poStyleMgr)
  delete poStyleMgr;
  poStyleMgr = NULL;
  if(!res)
     return false;
  return true;
      Thank you.
  To the world you're little, but to a person you're the world.
                                             Chen Xuexia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080817/39ef83fb/attachment.html
