[gdal-dev] Disabiling Geos messages via OGR
Mon Aug 18 10:20:51 EDT 2008
On 8/15/08, Brent Fraser <bfraser at geoanalytic.com> wrote:
> I'm using OGR's Geos functions (e.g. OGRGeometry::IsValid) to process some
> polygons.  Geos spits out messages to console (stderr?) like "Warning 1:
> Self-intersection at or near point ...".  Is there a way to disable these
> messages via OGR?
Brent,
OGR reroutes GEOS errors and warnings via the CPL error reporting
mechanism.  So, if you are working programatically you could
install a custom warning/error handler (see CPLPushErrorHandler()
for instance).
If you are just using the utilities there is no practical way to filter
out the GEOS messages other than by redirecting stderr to
/dev/null.
Best regards,
