[gdal-dev] OGRFeatureStyle update from version1.4.1 to 1.5.2;
wow 27949218 at qq.com
Mon Aug 18 21:13:16 EDT 2008
Hi,  Frank, welcome to China. I'd like to see you in Beijing, i'm sure that you're the  joss of many young students, hehe.
   I have found the reason why  failed to deal styles with ver1.5.2. Compared  with ver1.4.1,   CPLSPrintf() is replaced the CPLString().Printf()  , and i could trace the error to CPLString().Printf() every time debug. It might not allocate memory for the dest string in CPLString().Printf(). Of cource, if i still use CPLSPrintf(), no error occurs. Is this a bug in whole OGRFeatureStyle.cpp in ver1.5.2?
  To the world you're little, but to a person you're the world.
                                             Chen Xuexia
 ------------------ Original ------------------
 Date:  Mon, Aug 18, 2008 11:12 PM
 To:  "wow"<27949218 at qq.com>;
 Cc:  "gdal-dev"<gdal-dev at lists.osgeo.org>;
 Subject:  Re: [gdal-dev] OGRFeatureStyle update from version1.4.1 to 1.5.2;
 On 8/17/08, wow <27949218 at qq.com> wrote:
> Hi,
>   When i tried to update my whole program from ver1.4.1 to 1.5.2, all worked
> well except the  OGRFeatureStyle  module. The function
> OGRStyleMgr::AddStyle() couldn't write the provided style
> name and style string right with ver1.5.2, but could run smoothly with
> version 1.4.1.
>   My code :
Chen,
There has been some work on the style string parser since 1.4 and
I suspect it has been subtly broken for your case in some fashion.
Could you file a ticket?  Make sure you provide any additional
details we might need, like the format you are trying to write to.
Ideally a single small self contained program demonstrating the
problem would be best.
Best regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080819/7cc667b8/attachment.html
