[gdal-dev] GDAL 1.5.2 and GRIB2 support
Mateusz Loskot mateusz at loskot.net
Tue Aug 19 05:14:03 EDT 2008
Dmitriy Kazimirov wrote:
> Hi,
> Where GRIB2 support gone from 1.5.2?attempting to configure on Cygwin
> shows grib2 support no, grib directory is absent from frmts.
> Which of last versions support GRIB2?
Dmitriy,
What is the last version of GDAL you mean that included GRIB support?
I don't recall GRIB support in any of 1.5.0, 1.5.1 and 1.5.2.
GRIB support (frmts/grib directory) is available in SVN trunk
http://svn.osgeo.org/gdal/trunk/gdal/frmts/grib/
In February 2008, grib module was moved from spike [1] to trunk:
http://trac.osgeo.org/gdal/changeset/13877
[1] module for experimental, alpha and non-official codes
http://lists.osgeo.org/pipermail/gdal-dev/2007-February/011691.html
If you want to gest GRIB support, download the frmts/grib from trunk and
follow instructions explained here:
http://lists.osgeo.org/pipermail/gdal-dev/2007-February/011663.html
but replace URL
https://svn.osgeo.org/svn/gdal/trunk/spike/grib
with
https://svn.osgeo.org/gdal/trunk/gdal/frmts/grib/
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
