[gdal-dev] [Fwd: RE: ogr2gui on Linux]
Even Rouault even.rouault at mines-paris.org
Sat Aug 23 17:01:41 EDT 2008
I've attached a patch that enables ogr2gui to build on Linux and run
I'm not sure about the 'a_wx_string.mb_str(wxConvUTF8)' stuff that may not
work on Windows but that is necessary on Linux to get an UTF8 string instead
of a multi-byte unicode string. That unicode stuff in wxWidget is really a
But there's also a very important fix that must be applied for all platforms.
The OGRGetDriver ( an_integer ) call must be absolutely avoided ! It depends
on the drivers that are build in the gdal library. That may change for each
user (it didn't work with my GDAL build). Use OGRGetDriverByName
( "the_name_of_the_driver") instead. Another thing, when opening an OGR
dataset, you don't need to provide the driver. This is an output of the
OGROpen call in fact, and you can pass NULL if you're not interested by
knowing which source driver it is.
Best regards
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080823/fd1cec0b/Gui.cpp.bin
